2003 Chevy Silverado replaced heater but still no heat
NJTARTER
Heater problem
2003 Chevy Silverado V8 Four Wheel Drive Automatic
I have a 2003 Chevy 2500HD with the 6.6L duramax. The heater stopped working, I replaced the T-stats and still no heat. instead of ripping apart the entire dash to replace the heater core i installed an aftermarket heatercraft heater. The hoses are clear, and the supply hose gets got up to a foot from the block, but then cools down. My question is, is there a maximum length that the hose should be (mine are about 5') or what else could be causing the lack of water? i suspected the waterpump, but have no leaks, and the truck does not overheat. Thanks
Nov 18, 2009 at 5:51 AM
MERLIN2021
  • 17,250 POSTS
You didnt say how many miles are on it, but the vanes on waterpumps have been known to disolve over time, and first symtom is low/no heat, but enough vane left to cool the engine.
Nov 18, 2009 at 5:55 AM
