once i get calipers off do i have to just beat off the rotors or is there another step
Jul 21, 2009 at 1:37 AM
CEMENT HEAD
MEMBER
make sure that the little thin washer if still on there is removed the work the rotors back and forth with a rubber mallet or a dead blow hammer, also when u take the calipers off hang them up with a string or wire because if you dont you run the risk of damaging the brake lines.
