2003 Chevy Silverado poor acceleration
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
CATHY WILLIAMSON
slow to accelerate in all gears. once it reaches desired speed, runs great
Sep 16, 2009 at 9:27 AM
QUAGMIRE86
  • 98 POSTS
It may be as simple as a clogged air filter or a clogged fuel filter. They will let sufficient amounts of air or fuel through (the respective filters) at a low load situation but when you try to accelerate or initiate a high load situation, the blockage will not allow the call for large amounts of air or fuel to pass through the system. Also, a defective fuel pressure regulator will not supply enough pressure for the system during a high load encounter. And finally, if your fuel pump is weak, it will not push enough fuel through the system when called for.
Sep 18, 2009 at 4:19 PM
