I have changed APP sensor under gas pedal but still get 1125 code. Are there other APP senaors? And where are they?
Sep 13, 2010 at 6:24 PM
✓Experienced Mechanic
The aap sensor works in conjunction with the MAP sensor. There is only one. However, the code you are getting is related to the throttle position sensor.
P1125 Throttle position sensor intermittent
Have you checked that?
Sep 18, 2010 at 4:46 PM
CHARLIE7533
MEMBER
I have drive by wire. No throttle position sensor. Throttle body motor actuator.( it is riveted on where TPS used to be) Which i found out was the other side of the APP. Replaced it and bingo....thanks tho....
