2003 Chevy Silverado P1125
2003 CHEVROLET SILVERADO
240,000 MILES • V8 • 2WD • AUTOMATIC
CHARLIE7533
I have changed APP sensor under gas pedal but still get 1125 code. Are there other APP senaors? And where are they?
Sep 13, 2010 at 6:24 PM
  • 110,244 POSTS
The aap sensor works in conjunction with the MAP sensor. There is only one. However, the code you are getting is related to the throttle position sensor.
P1125 Throttle position sensor intermittent
Have you checked that?
Sep 18, 2010 at 4:46 PM
CHARLIE7533
I have drive by wire. No throttle position sensor. Throttle body motor actuator.( it is riveted on where TPS used to be) Which i found out was the other side of the APP. Replaced it and bingo....thanks tho....
Sep 19, 2010 at 12:17 AM
  • 110,244 POSTS
I'm glad you got it fixed.
Thanks for using 2carpros.com and take care.
Sep 20, 2010 at 8:14 AM
