2003 Chevy Silverado No Start
79,500 MILES • V8 • 4WD • AUTOMATIC
R G TRAPNELL
Starter/Solenoid won't engage at Start. Batt. OK. With shift handle in "P" & key position in ACC, shift position indicator shows "2". Turning key position to RUN, shift position indicator cycles from "2" to "P" and back to "2" where it stays. There have been no prior problem indicators.
May 11, 2009 at 1:36 AM
RHALL77
  • 3,361 POSTS
you may have a neutral safety switch going bad causing your problem. check and see if the connections are burned at the switch
May 11, 2009 at 7:45 AM
