2003 Chevy Silverado low and surging idle.
115,000 MILES • V8 • 4WD • AUTOMATIC
THOMAS0541
idle is 500 rpm after warm up. once warmed up it surges between 500 and 300 rpm. sometimes stalls once stopped. the more you mess with the brake the worst it gets.
Apr 9, 2010 at 8:14 AM
2CARPRO JACK
  • 11,533 POSTS
The vacuum loss will do that.Try removing the air intake at the throttle bore, with key on(if no throttle cable) have someone hold the gas pedal to the floor and clean out around the butterfly int hethrottle body.Coking will buil d up in there and can cause low/erratic idle.There is no Idle Speed Controller with a Drive-by-wire (No throttle cable) vehicle.So the coking will reallly mess with them. If this doesnt fix it, you may have a slow motor on the throttle body which requires replacement of the entire unit.Also be sure the tune up is in good order, a slight misfire can cause low/erratic idle as well.But cleant hethrottle bore for sure
Apr 10, 2010 at 3:28 AM
