2003 Chevy Silverado instrument cludter lite
114,000 MILES • V8 • 2WD • AUTOMATIC
TPJSTAN
The gear shift indicator lite is out. or the lite do not lite up to let you know what gear the vechile is in.
Apr 26, 2009 at 7:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
Is this gear selector digital or analog?
Thanks for using 2CarPros.com!
Apr 27, 2009 at 12:57 PM
TPJSTAN
the shift is analog. if you look very close you are able to see the letters. but, when the head-lights are turned on, the letters disappear.
Apr 27, 2009 at 4:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, first just make sure the interior lights dimmer switch is not all the way down. If this is OK, the bulb is most likely blown. You will have to remove the instrument panel and replace the bulb.
Apr 27, 2009 at 4:56 PM
