The gear shift indicator lite is out. Or the lite do not lite up to let you know what gear the vechile is in.
Sunday, April 26th, 2009 AT 2:42 PM
BLUELIGHTNIN6
MECHANIC
Hello
Thanks for the donation
Is this gear selector digital or analog?
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Monday, April 27th, 2009 AT 7:57 PM
TPJSTAN
MEMBER
The shift is analog. If you look very close you are able to see the letters. But, when the head-lights are turned on, the letters disappear.
Monday, April 27th, 2009 AT 11:45 PM
BLUELIGHTNIN6
MECHANIC
Okay, first just make sure the interior lights dimmer switch is not all the way down. If this is OK, the bulb is most likely blown. You will have to remove the instrument panel and replace the bulb.
