2003 Chevy Silverado Front Running light bulb is blown
30,200 MILES • V8 • 4WD • AUTOMATIC
TOXICKAVENGER
I have a 3157 bulb i figured out how to get the Head light assembly out but cnat to save my sole figure out how to remove the running lighht assembly
Help.
Feb 25, 2009 at 1:56 AM
F4I_GUY
  • 3,302 POSTS
To remove the headlight assembly, you will see upside down "L" shaped pins that go through the headlight assembly. Turn these pins so they are un-clipped and pull them upwards. The assembly will then be able to be pulled out and you can turn the bulb socket out.
Feb 26, 2009 at 10:39 AM
