2003 Chevy Silverado EVAP Code P0449
54,339 MILES • V8 • 2WD • AUTOMATIC
BUTCHW73
I have a code in My truck and it keeps coming back.
I tried to retighten the fuel cap and it is fine I inspected the seal and it is good and clean. I have replaced the EVAP control valve and still it pops right back up. How do you find the leaks on the hoses or In the sensor. or where is the sensor ?
Jan 23, 2010 at 2:45 AM
SCOTTY DEE
  • 592 POSTS
Flowing this particular code can be a real b****. You are going to need a scan tool to monitor fuel tank pressure as well as a smoke machine to determine if there are any leaks in the system. You will probably have to hire a technician to perform the necessary tests.
Look at it this way, you're already out the money for one part that didn't work, don't try for two!
Oct 31, 2018 at 11:57 AM
