engine light came on. local shop replaced a filter or something in gas tank last time the code came up. is this normal for the gas tank
Jan 2, 2008 at 5:19 AM
✓Experienced Mechanic
Have the OBD2 read out maybe its a different code/s this time and comeback with it.
Jan 2, 2008 at 5:28 AM
This would be normal if they replaced the fuel tank pressure sensor for an EVAP code, I would check you gas cap for the O ring to make sure it is good shape
