follow this info,The Throttle Actuator Control (TAC) / throttle body type trouble codes, may be caused by a loose wiring crimp at the throttle body connector, or a broken throttle body circuit.Inspect all related throttle body terminals for a loose wiring crimp. The loose crimp may be difficult to find, and the poor connection will be between the terminal and the copper strands of the wire. Wiggle test the individual throttle body circuits to see if the concern can be duplicated.
Inspect the related circuits for broken wires inside the insulation. The outer wire insulation may look fine, but the internal copper strands may be partially broken. Breaks in the wires usually occur within 1 to 4 inches of the throttle body connector. Wiggle testing may also induce a trouble code to set. On C/K trucks complete procedures for voltage drop on grounds G103 and G104. Grounds G103 or G104 may be loose or corroded.If a terminal crimp or a broken wire has been found, repair or replace only the circuits involved.try this and post back with what you find.
Mar 22, 2009 at 6:35 AM
