2003 Chevy Silverado check engine light on
93,359 MILES • 6 CYL • 2WD • AUTOMATIC
BOUNCEMAN
I have an 03 silverado. the check engine light is on. I was told of a evap leak when it went in for another problem found hose that was crimped off by dealer. This hose runs to a sensor of some sort on top of the motor, this has a plug with 2 wires out of it. I need to know what this sensor is so that i can replace it to pass NYS inspection. Thanks[img:c3b2ce8d05]http://www.2carpros.com/forum/automotive_pictures/149423_100_1692_1.jpg[/img:c3b2ce8d05]
Jan 27, 2008 at 7:30 AM
BRIAN 1
  • 1,030 POSTS
it's the evap purge solenoid.
Jan 27, 2008 at 9:07 AM
BOUNCEMAN
i greatly appreciate the info. Thanks again
Jan 27, 2008 at 1:25 PM
