My battery drains out like there is a draw why?
  • 109,885 POSTS
That is good advice. Remove the power to the alt but keep in mind, with the battery connected, the power to the alt is hot. One other thing about the alternator are the diodes in it. They are designed to allow power to travel in one direction only. If you have a bad one, it will short to ground and drain the battery. The alternator will still charge when the engine is running, but drain the battery when off.
Thursday, May 13th, 2021 AT 6:40 PM (Merged)
WEAZZZ22
  • 2000 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 115,000 MILES
Well one night there was a wreck on my road. I went up there to help, stoped turned my hazard lights on and the botton shot out. When I got back home the button would not stay down but the lights were still flashing so I pushed a little harder and the horn honked as the lights were flashing. The horn stoped and I stoped messing with it. So I took the fuse out so the hazards would stop flashing. The next moring I tried to start it the battery was dead. So I put the fuse in, the hazzards didnt work so I charged the battery got it checked it was fine. Then the blinkers didnt work and now everytime I turn the truck off about 5 or 6 hours later the battery is dead. PLEASE help me.
Thursday, May 13th, 2021 AT 6:41 PM (Merged)
What you got is a direct short to ground within the electrical system maybe and could involve the hazard circuit. Get a test light -disconnect the negative cable on the battery put test light between the disconnected cable and battery negative post-the test light will lit if you have a short in the system that's eating up the battery.
To find it start removing fuses one by one till the light turns off-this is where the trouble is located.
WEAZZZ22
Thanks man it worked I would give you points but I dont have any if I did I would give you 100
Its okay -half of the time it doesn't work or you don't have enough posts to do it. You have a nice day.
AGGIE 1
  • 2,000,000 MILES
Changed alternator, replaced battery. I am at a loss.
94 TRANSAM
  • 680 POSTS
Hello, We are sorry you are having troubles. Let me see if I can help you out.
If your battery is going from a full charge to dead over night it could be a couple of things.
1: Your battery has reached its life span and will no longer hold a charge. In which case you will need to replace it. Many part stores cant test your battery to see if it is good for free. Check with your local auto parts dealers to see who will do this for you at no charge. You can just walk in with the battery. You do not need to bring the car.
2: You have a draw on the battery that is draining it. Here is a link to show you how to test your system for a draw should the battery turn out to be fine:
https://www.2carpros.com/articles/car-battery-dead-overnight
If you need more help or have more questions with this issue please feel free to come back and ask. And if this resolves your issue please let us know. Have a great day! Rich.
EJ GOBERT
  • 1998 CHEVROLET SILVERADO
  • 4WD
  • 200,000 MILES
I replaced my battery and it worked fine for about a month then it would drain over night like the last one.
Thursday, May 13th, 2021 AT 6:42 PM (Merged)
  • 52,797 POSTS
Good morning.
Did you check the charging system?
If it is overcharging, it will boil a battery and fail the battery. Use a voltmeter and see if the charge rate is 14 to 14.5 volts.
Did you also check for a draw?
HARLEYMAN2
  • 1993 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 160,000 MILES
Is there any easy way to dectect a short, my battery is fine for about 4 days then dead, i've installed two new battery's and not the cheap ones, di the alternater test and thats fine.
Thursday, May 13th, 2021 AT 6:44 PM (Merged)
JDL
  • 16,098 POSTS
A battery drain with everything turned off? The best time to check for a lite staying on, is in the dark, under the hood, in the cab, somewhere. You can take battery cable loose, use testlite between cable and battery posts. If the lite is on, pull fuses one at a time. When you pull the fuse on the faulty circuit, the lite goes out. If you have a lite under the hood, you have to account for that and keep the doors shut.
DMPHILPOTT
  • V8
  • 4WD
  • 234,000 MILES
My pickup battery dies consistently after about 3 or 4 days of not running it. I've replaced the alternator and battery; also had them both tested and RE-tested. Pass with flying colors. Nothing is being left on in the truck. I've checked all lights including the courtesy lamps under the hood. My A/C hasn't been run in quite a while due to an issue with the "flap" that diverts air to the specified vents. When I shut off the truck or start it, it pops five or six clicks then stops and does it again for about 8 cycles. I cannot for the life of me find out why. I've pulled fuses one by one and found that with the vehicle off, the courtesy fuse arcs. This is the only one that does it. Also my amp gauge bobbles when the turn signal is used even at 70mph. Any ideas how to make this truck more reliable?
MMPRINCE4000
  • 8,548 POSTS
I would install a battery shut off on negative cable, when you turn it, it will cut battery power to engine.
This will erase clock settings and radio presets, but it will tell you if there is a battery drain.
Some autoparts stores have a device that will measure drains on battery when engine is off.
But drains are hard to isolate without proper equipment.
Also check relays with engine off, after engine cools, quickly touch relays, if any are hot, then relay is stuck.
PBMB04
  • 1992 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 93,000 MILES
Battery drains slowly when vehicle is parked for a period of time. Also, gauge shows charging at 14 amps when first driving but at later will only show a charge of 12 amps after driving for a while. Can you help in what I should be checking?
Thursday, May 13th, 2021 AT 6:45 PM (Merged)
  • 109,885 POSTS
I need you to check two things. First, we need to check if the alternator is working when it reads 12 volts. The 14 you mentioned sounds normal. If it drops to 12, the alt may be going bad. When it is reading 12 volts, run this test:
https://www.2carpros.com/how_to/how_to_test_alternator.htm
After that is complete, I need you to check for an electrical draw. Here are the directions for that:
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Let me know the outcome of both so I can point you in the right direction. If there is a draw, remove one fuse at a time to see what circuit is causing it. The draw should stop when you hit the right circuit.
PEDRO ANGEL MADERA
  • 4.3L
  • V6
  • 200,000 MILES
I just purchased this truck and it completely drains the battery within a day. I just bought a new battery and it was drained so I took it to the local store to get it charged. I measured it to be 11.6 volts. As soon as I plugged in the terminals it read 5.4 volts. I disconnected the terminals and measured the battery again and it was at 8.4 volts. I have made sure all lights are off, removed the stereo and still nothing.
Thursday, May 13th, 2021 AT 6:46 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
This definitely sounds like your vehicle has a parasitic draw issue. Parasitic draw is an industry term. We use it when, just like in your case, a vehicle has some kind of electrical draw that will drain a vehicle's battery, even when the vehicle is shut off.
I have included a link to a guide for you down below.
Please go through this guide and get back to us with what you find out. And make sure you have got a really good charge on your vehicle's battery before you start please. It will make things alot easier.
Thanks,
Alex
2CarPros
PEDRO ANGEL MADERA
I was getting a 50 mA draw. I found that it was the park-lps fuse.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Awesome, that's what we like to hear.
Thanks,
Alex
2CarPros
DAN NEFF
  • 1991 CHEVROLET SILVERADO
Battery goes down couple days. Battery cks o k. Alternator checks ok. Took positive cable loose from battery and measure resistance to ground get almost half meter reading, but open door or raised hood to when lights ( if connected ) would come on I get "0" resistance, which shows the positive cable is grounded.
Should there be any restistance any time cable unhook and where do I go to from here? What is causing the problem?
PS I cannot find any bare wires.
Thanks Dan
Thursday, May 13th, 2021 AT 6:47 PM (Merged)
