2003 Chevy Silverado ABS
57,000 MILES • V8 • 2WD • AUTOMATIC
RAVENHILL
My ABS Braking system is functioning when the pavement is dry. The ABS Light does not come on.
You can feel the pulsating on the brake pedal.
what can it be thats causeing this when the road is dry.
Nov 30, 2009 at 12:56 AM
DENNYP
  • 1,824 POSTS
If it is happening at low speed stops around 8mph, you need to remove the front wheel speed sensors from the hubs and clean the mounting surface for the sensors. The sensors will get corrosion buikt up under them. This will cause an excessive air gap between the sensor and tone ring resulting in unwanted ABS activation.
Nov 30, 2009 at 1:45 PM
