2003 Chevy Silverado 2003 chevy silverado SES code
2003 CHEVROLET SILVERADO
FRENIMY
Engine Performance problem
2003 Chevy Silverado V8 Two Wheel Drive Automatic
I have a 2003 Silverado 1500 5.3l Auto 98k I have had a low idle around 500 sometimes stumbling around 350-400. When I come to a stop the engine sometimes stalls and when I make a turn at an idle it will stall. I go the SES codes which are P0120, P0220, P0446, P0156, P1516, P1518, P2135. The SES light came on a couple days ago but the low idle has been happening before then. The low idle did get worse once the SES light came on. No recent work done. Truck has K&N cold air intake and flowmaster cat back exhaust. What should my first course of action be to fix this problem?
Jun 6, 2009 at 7:12 PM
PEAR69
  • CAR REPAIR CONTRIBUTOR
  • 1,482 POSTS
There are issues with loose grounds that will cause your problem.Tighten and check grounds G103 - located behind the passengers side cylinder head (just below the head itself) and attatched directly to the block with a 13mm headed bolt - and G104 - located behind the drivers side head and connected directly to the head but is very difficult to reach. Another ground to check is G110 - located on the outter drivers side fram rail.
Also, make sure the connection at the TAC (Throttle Air Control) module is good.. Your issue sounds like a dirty or loose ground..Once you check all the possible causes listed -- have the SES light reset by clearing the trouble codes. Autozone or a place like that will do this for free..Let us know how you make out.
Jun 8, 2009 at 12:52 AM
FRENIMY
Well I tried the grounds and checked the TAC connection. Tat didn't seem to change anything. Just a little more info a few weeks ago cleaned the motor and accidentally got water in the plug connection for the TAC when I tried to run the truck it wouldn't stay running and control panel said Engine Power decreased. I blew out the connection with compressed air and put it back together. Is it possible I shorted something out or need to have something re calibrated from that?
Jun 9, 2009 at 5:45 AM
PEAR69
  • 1,482 POSTS
Yes.
Jun 9, 2009 at 10:46 AM
FRENIMY
So what should I check and how can I do it. Is this something a repair shop has to do or only the dealer?
Jun 9, 2009 at 1:19 PM
PEAR69
  • 1,482 POSTS
You should have the ECU scanned with a dealers scan tool or equivalent scann tool. This will tell you where to look for the problem. Spraying water on any electronicaly controlled engine is a big no no. The TAC may be the problem, but proper diagnostic testing - with the proper scan tool - will save you money..All of the trouble codes point to a bad ground but an advanced scan tool will tell you for sure...
Jun 9, 2009 at 11:51 PM
FRENIMY
Thank you very much for our help this has been a really great site that happened to stumble upon and am telling everyone about
Jun 10, 2009 at 6:05 AM
PEAR69
  • 1,482 POSTS
Thank You.
Jun 10, 2009 at 1:41 PM
