2002 Door speaker
TOM1166
I have a 2002 5.3L Silverado 1500 LT extended cab. One of the speakers on the driver's door is shot (especially bad when the air is damp). I need to know how to remove the grill that covers the speakers. Do I use something like a paper clip through one of the holes or does it pry loose with a thin screwdriver or something like that?
Thank you!
Apr 11, 2007 at 1:37 PM
FIVE STAR
  • 5 POSTS
I'm pretty sure you have to remove the whole door trim panel to get at the speaker. 2 or 3 screws and the panel will lift straight up and unclip.
Watch out for the wiring for you power window controls. If you tug on them too hard you will bugger up the window switch block.
The speaker either unclips or is held in with 7 mm screws.
Don't pry on the plastic pieces too hard or you will break them. DO NOT TRY TOO PRY OFF THE SPEAKER COVER!
Apr 12, 2007 at 8:14 AM
