2002 Chevy Silverado won' start
197,700 MILES • V8 • 4WD • AUTOMATIC
NITROZORA
On my truck one day it would not start. I put in a new fuel pump,crank sensor. Then it ran fine then I turned it off now it won't start again but it turns over.
Oct 21, 2010 at 8:45 AM
  • 75,988 POSTS
Do you have a check engine light? If not do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 21, 2010 at 1:05 PM
NITROZORA
When i went to start my truck thi morning it did not start same thing when i got home from work. so i put some carb cleanere in it then it started rite up. dont know what is going on.
Oct 21, 2010 at 1:15 PM
  • 75,988 POSTS
When you turn key to run-do you hear the fuel pump come On? If so check the fuel pressure and get back with the readings
Oct 21, 2010 at 1:17 PM
NITROZORA
what would cause low fuel pressure? Where do i get the readings from?
Oct 22, 2010 at 3:00 AM
  • 75,988 POSTS
Weak fuel pump, leaky injectors and fuel pressure regulator-You check on the fuel rail test port
Oct 22, 2010 at 5:43 AM
NITROZORA
Thank you for all your help. I well let you know how it goes.
Oct 22, 2010 at 7:14 AM
