2002 Chevy Silverado Whining Noise From Rear ENd
2002 CHEVROLET SILVERADO
66,052 MILES • V8 • 4WD • AUTOMATIC
KHRISW
Hello Car Pro's!
Have a 02 Chevy 2500hd. Got a whine coming from rear end when i step on it at lower speeds.(10-20mph) At the same time the rear end shimmies. Without taking rear cover off i was going to order a loaded carriar bearing and the shim kit to replace. IS there anything else i should be looking for? Also i called to price a shim kit and bearing. Said was no shims for this rear end? Any help please.
Khris
Oct 5, 2010 at 5:09 AM
  • 110,240 POSTS
Before ordering anything, check the fluid to make sure it isn't contaminated with water or something other. You may have a bearing problem.
Let me know what you find.
Oct 6, 2010 at 12:32 AM
