2002 Chevy Silverado tune up
97,000 MILES • V8 • 2WD • AUTOMATIC
SANED72
hello
i had a tune up done to my truck, after a couple of days of driving, it started to miss, and shake a lot, also when stepping on gas it would not go right away.
took it back to the shop, and they told me it was because i didnt have the cables replaced.
is this a reason why it would do this?
Aug 30, 2008 at 12:35 PM
2CARPRO JACK
  • 11,533 POSTS
could be, at almost 100k they should have sold you plug wires when they did the "tune up". Most likely a wire was damaged from being pulled off the plug, but there is no way to tell for sure.Be sure they use OEM (A/C Delco) parts plugs, wires, cheaper is exactly that and your truck wont run as good
Aug 31, 2008 at 1:32 AM
