2002 Chevy Silverado TPS Malfunction
130,000 MILES • V8 • 2WD • AUTOMATIC
SALZMAN
I have 2002 Chevy 2500 that some times when when you start it up it has no power. Then if you shut it off for a while it may go away, what could cause it?
Nov 25, 2008 at 10:11 AM
  • 75,988 POSTS
The computer looks at the TPS/MAF/MAP sensor as engine load to adjust fuel and timing-also check the IACV
Nov 25, 2008 at 10:21 AM
