2002 Chevy Silverado started to idle rough than shut off wi
122,000 MILES • V8 • 4WD • AUTOMATIC
  • 6 POSTS
truck was idling and i notice it starting to run rough and then it shut off.
things I check were
1. for the fuel pump working (it is)
2 pressure at the fuel rail (there is)
3 spark at the plugs (there is)
4 check for engine codes ( none)
when trying to start it with no throttle it hits but does not start
Oct 5, 2010 at 4:17 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs
Oct 5, 2010 at 4:18 AM
