2002 Chevy Silverado problem with my pick-up when it's cold
125,000 MILES • V8 • 4WD • AUTOMATIC
HARVEYSKIS
I have a Chevy Silverado 1500. It doesn't idle well when the temp outside is cold (like below 25 degrees of so). Even when the engine is warm, it still will idle poorly. Not so bad that it stalls, but close. It is all right when i'm actually driving it instead of idling. It does not do this when the weather is warm - only when it's cold outside. Any advice would help. Thanks.
Dec 3, 2009 at 9:57 AM
  • 75,988 POSTS
Try cleaninig out the IACV, EGR/PCV Valves and test the TPS/MAP sensors
Dec 3, 2009 at 11:23 AM
