2002 Chevy Silverado Power window failure
75,000 MILES • V8 • 2WD • AUTOMATIC
MILLERA
I have replaced my driver side power window three times in a year and a half. What could be causing this?
Dec 14, 2009 at 11:39 AM
  • 110,251 POSTS
Check to make sure it is getting 12+ volts to the motor. If it is, make sure the switch is shutting off when you release the button. If it sticks for a short period of time, it could cause this too. Finally, if all is well, maybe you should try a different brand of motor. Many of them are made overseas and not too good.
Dec 18, 2009 at 2:44 AM
