2002 Chevy Silverado Power window
100,000 MILES • V8 • 2WD • AUTOMATIC
BLAZERDEER
How hard is it to change out the driver side power window regulator? I removed the door panel and found the cable snapped.
Sep 18, 2010 at 6:43 AM
99SILVERADO4.8
not hard at all..its going to come as an assembly most likely with the motor already mounted on the tracks. from memory theres a 10mm bolt in each corner of the tracks 1 10mm bolt going into the window motor and maybe 1 more hiding somehwere. also the window is held in place by 2 10mm bolts that kinda pinch the window in place with these weird rubber clamp lookin things. be sure to secure the window from falling down..i jus stuck 2 screw drivers through some holes in the door to catch it from failling. anyways..once its all un bolted bring the 2 tracks together turn sideways and pull them out from that horizontal opening at the bottum of the door
Sep 20, 2010 at 4:05 PM
