2002 Chevy Silverado Popping Noise when turning
2002 CHEVROLET SILVERADO
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
MMORRIS5M
  • 8 POSTS
I hear a popping or clicking noise when I am making a turn over an uneven surface. For example: While turning into the drive way or when I am turning while going over a speed bump. What should I check first? I was told by two other people that they had the same problem and it turned out to be the steering column. They said that the dealership had to grease the steering column through a "special fitting". Have you ever heard of this? If so, do you know where the grease zerk is and is it accessible?
Feb 21, 2008 at 2:05 AM
Have the CV joints checked and also the front suspension components
Feb 21, 2008 at 6:58 AM
2CARPRO JACK
  • 11,533 POSTS
That would be the intermediate shaft on the steering column. If there isnt a grease fitting, they (dealer) will drill and install one. Also might want to look at the shock bushings
Feb 21, 2008 at 7:10 AM
