Where is the resistor assembly located
BUTCHY51
where is the resistor assembly located. how to replace i.e. remove center console or dash?
Mar 14, 2010 at 1:27 AM
MERLIN2021
  • 17,250 POSTS
This is for manual system, auto temp(automatic) is different! BLOWER MOTOR RESISTOR Removal (Front) If equipped, remove the I/P sound insulator. Disconnect the electrical connection from the blower motor. Disconnect the electrical connection from the blower motor resistor. See Fig. 28 . Remove the blower motor resistor retaining screws. See Fig. 29 . Remove the blower motor resistor. See Fig. 30 . Fig. 28: Disconnecting Electrical Connector From Blower Motor & Blower Motor Resistor Courtesy of GENERAL MOTORS CORP. Fig. 29: Removing & Installing Blower Motor Resistor Retaining Screws Courtesy of GENERAL MOTORS CORP. Fig. 30: Removing & Installing Blower Motor Resistor Courtesy of GENERAL MOTORS CORP. Installation (Front) Install the blower motor resistor. See Fig. 30 . Install the blower motor resistor retaining screws. See Fig. 29 . Tighten to specification. See TORQUE SPECIFICATIONS . Connect the electrical connection to the blower motor resistor. Connect the electrical connection to the blower motor. See Fig. 28 . If equipped, install the I/P sound insulator. Page 1 of 1 3/14/2010 ...
https://images.2carpros.com/forum/automotive_pictures/62217_bmr2_1.jpg
Apr 30, 2021 at 9:01 AM
