2002 Chevy Silverado INSTRUMENT PANEL
37,000 MILES • 6 CYL • 2WD • AUTOMATIC
DISTURBEDRIDEZ
After changing battery my dash lights stay on
low fuel
battery
security
abs
air bag
gas gauge not working
spedo working fine
truck is runing fine
what do you think?
Chuck
disturbedridez
May 29, 2008 at 7:35 AM
MERLIN2021
  • 17,250 POSTS
Try removing the negative cable only with the key and engine off... leave off for 10-15 mins and try it.
May 29, 2008 at 7:38 AM
DISTURBEDRIDEZ
Thanks merlin i tryed the battery neg off trick for 30 min. and still have same problem.
will look for new fix befor dealer.
Thanks again
Chuck
disturbedridez.com
May 30, 2008 at 5:23 AM
MERLIN2021
  • 17,250 POSTS
Can it be driven? Speedo working or not? Could be it need a new cluster, but have it scanned first by a shop that can read B codes.
May 30, 2008 at 6:51 AM
DISTURBEDRIDEZ
Truck runs fine
speedo works fine
not gas gauge
and all the light stay on as posted befor.
could be cluster it is after market spider cluster
or it could be something with the computer?
Thanks again
Chuck
May 30, 2008 at 12:59 PM
MERLIN2021
  • 17,250 POSTS
Scan it before spending the money, but I'd go with the cluster.
May 30, 2008 at 7:40 PM
DISTURBEDRIDEZ
Thanks again Merlin will let you know the outcome.
Chuck
disturbedridez.com
May 31, 2008 at 10:19 AM
DISTURBEDRIDEZ
Well thanks for the help Merlin i tryed everything
to clear my cluster light so went to a shop to scan
no reading got home and really went over wiring.
wire that i installed to alt. had a bad spot that had rubed to the inside-shorted- giving me the lights on my panel freakin my computer out!! Rrplaced wire removed the ground for 20min Wala! computer reset and all is well. This is the kind of problems i bring on myself for customizing my ride. Thanks again for your input it is folks like you that make the internet a cool place to visit.
Chuck
disturbedrides.com
Jun 14, 2008 at 3:50 AM
MERLIN2021
  • 17,250 POSTS
Thaks for the kind words! I checked out your site..pretty neat! Think about using plastic conduit with new wires!
Jun 14, 2008 at 4:58 AM
