When turning on the ignition before daylight or after dark, my headlights don't come on, instead my parking lights come on and an indication that my high beams are on appears. I can turn the switch from auto to any position and/or push the dome override button and no change occurs. It started out happening for a little while then they would come on, and other times I can drive over ten miles and no change. The other day I drove ten miles to work with no headlights, turned the truck off and on again with no change. When I turned off the ignition and opened the door then shut it, came back to check again and they came on.
I wonder if the High beam indicator might be some kind of code?
Others I have talked to said to disconnect the battery and reconnect it to reboot the computer but I have not done this yet. Any Ideas?
SPONSORED LINKS
Wednesday, September 9th, 2009 AT 5:41 PM
