2002 Chevy Silverado headlights
18ANIMALS
Electrical problem
2002 Chevy Silverado V8 Four Wheel Drive Automatic
headlights go out on their own. can get them to come back on by raising and lowering the tilt wheel. but now they're out completely. suspect the mulitfunction switch.
Oct 9, 2008 at 12:12 PM
RACEFAN966
  • 5,029 POSTS
A few questions first. Is the column loose at all? I could be a wire broke or the multi function switch. If the column is good and tight then the switch would be the first thing I would look at. Let me know what you find.
Oct 11, 2008 at 7:41 AM
18ANIMALS
steering column is fine,it's the low beams only,the brights work fine.
Oct 11, 2008 at 10:13 AM
RACEFAN966
  • 5,029 POSTS
Well with that is sounds like the combination switch is getting hot and shutting off or something inside is just bad.
Oct 11, 2008 at 2:54 PM
