I have a 2002 Silverado 4.3L 95000 miles thats not holding fuel pressure and I cant find why? I have replaced the filter, pump, regulator and injector o-rings. When I first turn the key the pressure shoots up to 60psi then as soon as the pump cuts off it falls to around 25psi and holds there..it will run if I crank it around 50psi but misfires and gives the P0300 reading. So what am I missing? I thought it was a bad fuel pressure regulator to start with but that didnt solve it..I even replaced it again.. I plugged the return line and the pressure held around 55psi and it ran fine..what else could it be? Frustrated! ugh! lol thanks guys for your help
Jul 21, 2010 at 1:13 AM
