run for about 5 seconds it died and will not start?
NATHANIEL SORRELS
I have a 2002 chevy 2500HD it ran out of fuel took all the steps to get it started. I got it to start and run for about 5 seconds it died and will not start back now it trys but now you can here it pushing air back through the air cleaner I have no i deal what is wrong with it please help
Apr 4, 2009 at 7:12 AM
BRIAN 1
  • 1,030 POSTS
possible bad injection pump,very common problem on these. the pump is very delicate,any dirt or contamination ruins these pumps. what steps did you take to get it started? also scan for codes and take a vacuum reading at the fuel rail,should be 8psi,or use a scan tool and monitor vacuum on the scan tool should be 1-1.8 mpa.check for any fuel contamination and ice blockage at the fuel pump lines.and excessive fuel in the crankcase which would cause low or no compression.post back with what you find.
Sep 2, 2020 at 6:17 AM
DENNYP
  • 1,824 POSTS
The most common problem on the D-MAX is a restricted or leaking fuel filter. The fuel filter MUST be replaced every 15,000 miles. They are very sensitive to contamination. If there are any leaks at the filter or anywhere on the supply side, air will get in the fuel system and cause a hard or no start. Try removing the black plastic plug from the filter housing, then pump the primer button until you get a steady stream of fuel. Install the plug. Pump the primer about 10 to 20 more times, then try to start the engine.
