2002 Chevy Silverado Clutch pedal broken
2002 CHEVROLET SILVERADO
85,000 MILES • 6 CYL • 2WD • MANUAL
STORMRIDER27
The clutch pedal on my Silverado just broke. There is a plastic piece that goes through the fire wall that secures the master cylinder and this is what broke. What is involved in repairing this? What parts NEED to be replaced and which ones should also be replaced.
Thanks
Oct 20, 2009 at 9:42 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Plastic piecs is it attached to pedal and looks like a push rod? Is there any fluid leak? was pedal extremely hard to deppress before it broke?
let me know
Thanks for donate
Oct 21, 2009 at 2:28 AM
STORMRIDER27
The plastic piece that is broken in the part that holds the push rod onto the firewall. The master cylinder is not leaking ( i checked right after I was able to park fluid was to the full line). Before hand the pedal was fine (neither soft or hard to push). The truck did not like to shift into first and second when you first drove it in the am.
Thanks again
Jason
Oct 21, 2009 at 10:08 AM
DOCFIXIT
  • 18,828 POSTS
That is retainer don't think part of master could not find in GM parts. Call Dealer see if they have part.
Oct 22, 2009 at 2:37 AM
STORMRIDER27
I have been told that I need to replace the clutch pedal assembly (this makes sense it appears to be one piece). They also want to replace the master and slave cylinder which sounds like a bunch of crap to me.
Thanks
Oct 22, 2009 at 3:39 AM
DOCFIXIT
  • 18,828 POSTS
The pedal assembly is what I got from dealer couple minutes ago. I'm with you if master and slave good why replace. They aren't cheap
Oct 22, 2009 at 3:48 AM
