2002 Chevy Silverado Clicking Noise on hot days
68,000 MILES • V8 • 4WD • AUTOMATIC
SOPMOD
When I turn on my A/C during hot days, which is usually in high 80's and above degree days, I get a "clicking" noise. I have isolated the noise to A/C unit, for it only makes this noise when I turn on the A/C. This noise is very similar to a noise that we as kids used to produce by attaching a playing card or a thin piece of plastic to the bicycle frame to rub against the bicycle wheel spokes, creating a constant clicking sound. The noise last anywhere from 3 to 7 seconds and I have learned to mitigate the noise by controlling the throttle, either accel or decel. Again, it only makes this noise when the A/C is turned on during very hot days, while it does not usually occur during cooler days when I turn the AC on.
Any expertise advice is much appreciated.
Jesse
Jul 28, 2010 at 4:19 AM
  • 110,248 POSTS
It sounds like a bearing may be going bad in the compressor. Is the belt in good condition?
Aug 1, 2010 at 4:23 PM
SOPMOD
Thank you very much for your reply...
The belts are in good condition with proper tension. As I have mentioned before, this sound only occurs during hot days when I turn-on the A/C. I have also isolated the noise to the right front corner of the vehicle, where the compressor and AC unit is located.
Aug 2, 2010 at 2:04 AM
  • 110,248 POSTS
Chances are it is the compressor.
Aug 2, 2010 at 5:51 PM
