2002 Chevy Silverado check engine soon light code indicate
65,000 MILES • V8 • 2WD • AUTOMATIC
CHEVY2002
Periodically my check engine soon light will come on, the code indicates too lean on both banks. The fuel filter has been changed the air flow sensor has been cleaned. The fuel pressure reads good. It also idles rough, like there is a miss. How can I identify exactly what is causing the problem?
Feb 18, 2008 at 1:48 PM
BLACKOP555
  • 10,386 POSTS
first buy 1 o2 sensor and replace it and see if the code stops on that bank.
if it was misfiring you would get a p030* code.
vs the p0174 p0171 code you are getting.
Feb 18, 2008 at 2:03 PM
JACKSKI
  • 11 POSTS
check out replies on first page of forums of " rough and uneven cold start ups " this might be your problem!! jackski
Feb 27, 2008 at 10:57 AM
