Brakes problem
2002 Chevy Silverado V8 Two Wheel Drive Automatic
Brakes lights and abs lights are both coming on when driving and staying on.
Any suggestion where to start looking for the problem
Sunday, June 8th, 2008 AT 1:18 PM
THE FACTORY MAN
MEMBER
When both the ABS and Brake lights are on that can indicate an issue that involves safe driving. The Red Brake light may indicate a parking brake issue or a fluid level issue. Check both those systems. The ABS light may require a scan to pull codes but visually look over the system for any unplugged connectors, damaged wiring, etc.
