2002 Chevy Silverado back up lights
BOB HICK
Electrical problem
2002 Chevy Silverado V8 Two Wheel Drive Manual
How do you change the back-up (relay, switch, what ever it is called) on the transmission? My back up lights went out. I've checked fuses and bulbs.Mechanic said it could be the relay on the transmission. Been under the truck and see a couple on wiring plugs going into the tranny.People at Auto Zone weren't able to help me.I hope I don't have to go to the dealership and get bent over for a ten minute fix.I try to do as much as I can myself.
Dec 26, 2009 at 11:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the back-up lamp switch is located on the left side of the transmission. disconnect the battery, raise vehicle safely for access to switch, disconnect switch connectors then unbolt switch from mounting location.
Dec 26, 2009 at 2:13 PM
