2002 Chevy Silverado auto seats and horn stopped workin
2002 CHEVROLET SILVERADO
1MONKEYMATT
Electrical problem
2002 Chevy Silverado 6 cyl Four Wheel Drive Automatic
my seats and horn have stopped working and the 25a fuse is hot to the touch what could the probem be
Feb 22, 2009 at 1:02 AM
JDL
  • 16,098 POSTS
Hello, there should be a horn relay in the power distribution center under the hood. You can unplug the relay, use a testlite, two terminals should be hot? You can use a fused jumper on the switch/ load side of relay, the horn should honk. If it does, the problem may be on the control side of relay, ground. I can't rule out the relay at this point, the fuse for that circuit shows 15 amp.
I saw a 25 amp circuit breaker for the power seats. If that breaker is hot, maybe something wrong with the seat motor or something is causing a load on the motor?
Feb 22, 2009 at 7:31 AM
