2001 Silverado 1500 vibrations
ARMYCHEVY
I have a vibration in the rear end of my truck. I have been trying to figuare it out for a while now and figured I would ask around. This is whats going on from 0 to about 20 mph the rear end has a vibe. I have check the counter weights on the drive shaft and balanced the tires about three times. I also have changed the u-joints but its still there any toughts on this would be greatly appreciated
Dec 29, 2006 at 6:21 AM
CHRIS_KOLAR
  • 10 POSTS
This sounds like you have tires that are scalloped I would try rotating the tires from front the back to see if it changes.
Dec 29, 2006 at 6:00 PM
ARMYCHEVY
Yep you nailed it I could see the tire tread having a problem I just didn't think it would make such a noise. Thanks for you help buddy.
Jan 9, 2007 at 6:10 PM
