2001 Chevy Silverado water building pressure and comming ou
137,000 MILES • V8 • 4WD • AUTOMATIC
DURDEN5
the thermostate has been changed, the head gaskets replaced, new water pump. Water builds up and comes out of the reserve tank. You can idle the truck and it wont do it,but once you drive about 2-3 mls. the water is coming out still after all the above.but since the head gasket change the water does not come out the hose that runs up the side of the radiator when you crank it. any advice?
Apr 28, 2010 at 4:24 AM
  • 75,988 POSTS
Check if the radiator is clogged and also the radiator cap
Apr 28, 2010 at 7:31 AM
