2001 Chevy Silverado swishing noise under dashboard
KEVINLB
MEMBER
2001 CHEVROLET SILVERADO
6 CYL
4WD
AUTOMATIC
70,000 MILES
Water noise under dash, heater core not leaking drain is open
Monday, February 16th, 2009 AT 6:38 PM
MASTERTECHTIM
MECHANIC
Are you low on coolant? Clean and or replace radiator cap. If cap is faulty then you will run without sucking coolant from overflow jug and it will cause air pocket in system and thus causing swishing noise
