2001 Chevy Silverado performance responce
MAYA JR
  • 2001 CHEVROLET SILVERADO
  • 6 CYL
  • 160,000 MILES
The engine will respond very little when steping on the gas pedle
Tuesday, February 16th, 2010 AT 6:56 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Tuesday, February 16th, 2010 AT 8:15 PM
