2001 Chevy Silverado Steering rubbing
65,000 MILES • V8 • 4WD • AUTOMATIC
NEWTC84
  • 38 POSTS
I have a 2001 Chevy Silverado 4x4 with the 5.3 liter V8 and 65000 miles. I recently bought the truck and did an oil change. While I was under the front end I decided to grease the zerks. Shortly after I noticed a rubbing noise when turning at slower speeds, almost as if the power steering fluid was low, but it was not. I had a 2002 truck almost identical to this one before, and I experienced the same problem only after I started greasing the zerks. My question is, if there are different kinds of grease, maybe I am using the wrong one, or if Chevy uses a special kind to lube their vehicles. What could be going wrong?
Sep 27, 2008 at 1:31 PM
2CARPRO JACK
  • 11,533 POSTS
No, they dont use any special kind of grease that could cause this problem.Does it make the noise the same on right and left turns? Does the p/s fluid smell or look burnt? (dark in color) if so you may want to flush the p/s system and use fresh fluid
Sep 29, 2008 at 7:10 AM
NEWTC84
  • 38 POSTS
It makes the noise pretty much the same left and right, but seems to be more obvious and common when turning left. I will check the steering fluid, and maybe flush the system. Thanks for the help.
Sep 29, 2008 at 10:20 AM
