2001 Chevy Silverado Steering is hard to turn when turning
68,000 MILES • V8 • 4WD • AUTOMATIC
BENNADETTA
My steering is hard to turn to the right, but I dont't have this problem when turning the steering to the left. Also when turning the steering wheel to the right you hear like a air sound inside the truck but you don't hear this when you are outside the truck. The power steering pump was replaced and the problem still exists. There are no leaks under the truck. What may be the problem?
Nov 29, 2008 at 12:56 AM
DOCFIXIT
  • 18,828 POSTS
Problem is in steering gear unit. Did pump shaft break ? If so metal may have entered system and is effecting gear.
Nov 29, 2008 at 4:04 AM
