2001 Chevy Silverado speedometer
WCJONES
Transmission problem
2001 Chevy Silverado Four Wheel Drive Automatic 153,00 miles
I replaced the transfer case in the truck now the speedometer dont work and the truck will not change gears. The abs light is on and put it on the computer but will not give a code what can i do to fix the issue.
Jun 8, 2008 at 1:12 AM
MERLIN2021
  • 17,250 POSTS
If all was working b4, change the VSS(vehicle speed sensor) on the left side of the case back to your old one...
Jun 8, 2008 at 2:02 AM
WCJONES
had to put old transfer case back in the rebuilt one had the same amount of play as the old on so all the sensors are the ones that was in the truck to start with.
Jun 8, 2008 at 3:21 AM
WCJONES
Could I have missed up the pcm when i changed the transfer case before i changed the transfer case my gas hand would jump up and down and now the speedometer dont work and my abs light is on and the gas hand is still jumping just like it was.
Jun 8, 2008 at 6:50 AM
