2001 Chevy Silverado slow leak ifrom transmission lines
120,000 MILES • V8 • 2WD • AUTOMATIC
WOODHAMJ
The transmission lines connected to the radiator have a slow leak. The end nut is tight, but the lines move when when wiggled.
Jan 17, 2010 at 1:38 AM
DOCFIXIT
  • 18,828 POSTS
Would indicat either seat in radiator orouble flair on line damaged. Lines been removed? Try removing and applying teflon tape to threads
Jan 17, 2010 at 6:38 AM
WOODHAMJ
I bought a new O-ring and will use teflon tape also. Is the Teflon tape heat resistant?
Jan 17, 2010 at 12:09 PM
DOCFIXIT
  • 18,828 POSTS
Tape will easily withstand the cooling fluid temp.
Jan 21, 2010 at 2:07 AM
