2001 Chevy Silverado "Creeking/Rubber,"Noise from
125,000 MILES • V8 • 2WD • AUTOMATIC
TRAVIS862001
  • 5 POSTS
This just started happening last night. I was going through a drive thru and I was hearing a creeking/rubber noise coming from the left front wheel while just idleing through the parking lot. When I get going I believe it goes away. It does not make the noise when I apply the brakes, but only when i am going at slow speeds. It makes the noise as the wheel rotates.
Jan 20, 2009 at 9:36 AM
DENNYP
  • 1,824 POSTS
Does your truck have the plastic chrome wheel covers?
Jan 20, 2009 at 2:16 PM
TRAVIS862001
  • 5 POSTS
chrome rim but plastic lug nut covers
Jan 21, 2009 at 11:31 AM
DENNYP
  • 1,824 POSTS
Try to have someone walk along side the truck while you are moving. You might have a chrome overlay on the wheel that is loose.
Jan 22, 2009 at 4:51 AM
TRAVIS862001
  • 5 POSTS
I have suspected the hub assembly having to be replaced because of the left front wheel bearing but would it make that sound at a very low speed?
Jan 25, 2009 at 10:09 AM
DENNYP
  • 1,824 POSTS
Yes, you can get noise from the hub at low speeds. You can drive at about 40-50mph and steer side to side and see if you get a noise. The hubs usually make noise to one side and not the other.
Jan 25, 2009 at 1:54 PM
TRAVIS862001
  • 5 POSTS
the cause of the creak sound was the left front brake.. it is staying applied although the pedal is not being applied.. i took the brake caliper off and the brakes, pushed back the pistons and two weeks later its doing it again.. what would cause it to stay compressed?
Feb 12, 2009 at 11:34 AM
DENNYP
  • 1,824 POSTS
You could have a bad caliper or brake hose.
You can test for this with the help of an assistant.
Have someone pump the brake pedal several times, then let off. After they let off, wait 2 seconds then open the brake bleeder on the suspect caliper. If brake fluid trickles out, the caliper is at fault, or you have caliper slides that are binding. If fluid shoots out, the brake hose is the problem.
Feb 13, 2009 at 12:43 AM
