2001 Chevy Silverado PROBLEMS W/ GM CRATE TRANS. W/ ONLY 38
BBMAN502
  • 2001 CHEVROLET SILVERADO
  • V8
  • 99,300 MILES
IT HAS JUST STARTED WHINING AND WHEN CHANGING FLUID IT WAS WAY TOO DARK ( LOOKED LIKE OLD MOTOR OIL ) THE REASON I CHANGED IT TO BEGIN WITH WAS IT STARTED SHIFTING REAL HARD AND THE CONVERTER WILL NOT GO INTO LOCK UP SO MY RPMS @65 STAY AT LIKE 2200. JUST CURIOUS THE TRANS HAS A WARRANTY FOR 100,000 MILES BUT IF I CAN AVOID LEAVING MY TRUCK AT A DEALER FOR 3 DAYS I WILL. THANK YOU IN ADVANCE.
Wednesday, March 26th, 2008 AT 9:20 PM
THE FACTORY MAN
  • 50 POSTS
If it is warranteed for 100,000 miles and you have only 700 miles left of the warranty I think I would not be fooling around with it if you suspect you are in the process of having a major failure. I would get it to a dealer.
Take your CAPS LOCK off.
Thursday, March 27th, 2008 AT 9:41 AM
DENNYP
  • 1,824 POSTS
Could be a bad converter or pump.
Saturday, March 29th, 2008 AT 7:00 PM
