2001 Chevy Silverado power steering and brake failure
152,000 MILES • V8 • 4WD • AUTOMATIC
PJBLACKLOCK
Today when I started my truck (01 Chevy 2500 HD Duramax) both the power steering and power brake systems were not operating. The drive belt appears to be functioning correctly. Brake fluid is a little below the max line but well above the min line. Power steering fluid level is close to max. We did tow our horsetrailer with a light load yesterday and the trailer is still hooked up. Are there any troubleshooting tips you recommend?
As an updated, I ended up driving it without power brakes and steering over to my shop and about midway there, after making a tight turn, both systems came back...any ideas why both might go down and then return?
Thank you!
Mar 30, 2008 at 4:54 AM
MERLIN2021
  • 17,250 POSTS
remove the serp belt, and pull on the PS pulley, these are known for the shafts in the pump snapping...
Mar 30, 2008 at 5:14 AM
FLEXY5
  • 512 POSTS
If it is a diesel, the reason why they BOTH went out at the same time is because the P/S pump feeds the brake booster for the power brakes.
Mar 30, 2008 at 11:18 AM
